โApr-20-2023 05:25 PM
โApr-24-2023 06:16 AM
ford truck guy wrote:MFL wrote:
No apology needed on these forums. Happy your buddy was able to clear it up!!
No reason to start drinking now, especially with recent legalization of weed! ๐
Jerry
A side of Jerry I didn't know ! ! ! ! :B
โApr-24-2023 04:46 AM
Jerry
โApr-23-2023 07:59 PM
โApr-23-2023 05:08 PM
โApr-23-2023 04:55 PM
โApr-23-2023 02:03 PM
wing_zealot wrote:
Just who is the "they" you are referring to? There are 3 people involved here.
1) The axle manufacturer welded the spring perches to the axle.
2) The trailer frame manufacturer welded the spring shackles to the trailer's frame.
3) All the installer of the new axle did was remove a few bolts, swap out the axle, and re-install the bolts. Any teenager with the right wrenches could take the old bolts out and put them back in (even torque them correctly).
So who is the incompetent "they" guy you are inferring to?
fj12ryder wrote:
Actually I can't see any harm with a 1/2" short on one side, as long as the axle is parallel to the other axle and straight and true. The tires aren't going to care whether they're directly in line with the one in front of it. No reason to think there would be any tire wear at all. It's way different from front end of a car/truck. Different story if the axles is incorrectly aligned, or bent.
First, it is normal for axles to walk side to each as you turn. I would think if you stopped to check while going in straight line both axles should be centered.
โApr-23-2023 09:26 AM
JRscooby wrote:Actually I can't see any harm with a 1/2" short on one side, as long as the axle is parallel to the other axle and straight and true. The tires aren't going to care whether they're directly in line with the one in front of it. No reason to think there would be any tire wear at all. It's way different from front end of a car/truck. Different story if the axles is incorrectly aligned, or bent.fj12ryder wrote:
I agree that a 1/2 inch isn't going to affect anything. Centered up, that amounts to 1/4" per side. Just can't see any issues with that.
Yes, "centered up", that's not much. But OTOH,You can see it on the drivers side. The curb side is lined up like it should be.
Makes me wonder about how well it is centered? But even worse, if they where sloppy at getting it centered, how close was acceptable when it comes to making sure the axles are running true to each other and frame?
If axles where same length, measure center to center on each end, the numbers should be same. And that would work out if the centers of both axles and kingpin where on same line. But I would think axle center 1/4 inch off that line would show up as tire wear in relative few miles. (Look at toe in measurements for your TV, and how fast tire wear shows up if that's off. That's 2 tires pushing against each other. Would be better with 2 pair fighting?
โApr-23-2023 06:44 AM
โApr-22-2023 01:38 PM
โApr-22-2023 11:29 AM
โApr-22-2023 06:24 AM
โApr-21-2023 04:30 AM
โApr-21-2023 03:20 AM
TenOC wrote:shadows4 wrote:
H
Got under the trailer today and the new axle is 1/2 inch narrower than the original.
Diameter or length????
โApr-21-2023 03:09 AM
H
You can see it on the drivers side. The curb side is lined up like it should be. Is this going to be a problem down the road? Thanks.
