- tj9267inIndyExplorerThere is an app for iPhone called Truckers Path that is very good. Shows stops of all kinds, rest stops, Walmarts, etc. I use it when I'm out and it has proven to be very accurate. Not sure if it is applicable to Android.
- C-BearsExplorer
B.Sjulestad wrote:
Hope someone can help. I'm looking for a RV friendly (40' 5TH) fuel stop (diesel) about 1/2 way between Denver and Grand Junction on I70.
IMHO is you are pulling a 40' fiver you need to be getting your diesel where the trucks are getting theirs, for example Flying J, Pilot, Loves, etc. It is only a matter of time before you either cause damage, or get damage trying to squeeze your 55'-60' rig into gas stations made for cars. - dutch1724Explorerhttp://www.pilotflyingj.com/rv-amenities
- mferris72ExplorerGet the I Exit APP for your phone. It will tell you whats at each exit and also if there's RV friedly Lanes.
- samsphonesExplorer
B.Sjulestad wrote:
There are no truck stops on this stretch. I Googled and found a Sinclair station in Eagle Colorado that looks like it might have a RV friendly pump island, just wondering if anyone has had any experience driving this stretch.
This is not true, if you go to www.findfuelstops.com and put in denver as origination and grand junction as destination you wil find 18 TRUCK STOPS, a few are 15-20 miles off interstate but there are 2 right on interstate. Google is not a good place to find truck stops. - RockyMtExplorer III stop in Gypsum, station is about a half mile off the highway. Glenwood is also a choice first exit call West Glenwood, tight but usable. Easy on and off there but it is tight.
- laknoxNomad
ChopperBill wrote:
Unhook or throw a couple of five gallon jugs of fuel in the truck.
My thought. Fuel would almost certainly be cheaper in Denver, too, if you don't stop.
Lyle - FlatBrokeExplorer IIUnhook or throw a couple of five gallon jugs of fuel in the truck.
- B_SjulestadExplorer II
rhagfo wrote:
I will play devils advocate and ask WHY? 250 miles or so do you have a short bed and small tank? It is basically a down hill tow, you should get at least 10 mpg, if not 12 mpg. I could get there with an easy 80 miles of fuel left.
That said, you do realize that all service stations get filled by double tankers. They fit just fine, you just need to look ahead as you approach.
True but I will be going from Grand Junction which is uphill, not sure what kind of mileage I will get so I'm trying to plan ahead just in case. The tanker trucks do not have to go through the islands,
they usually fill at the end of the drives/lots. - rhagfoExplorer IIII will play devils advocate and ask WHY? 250 miles or so do you have a short bed and small tank? It is basically a down hill tow, you should get at least 10 mpg, if not 12 mpg. I could get there with an easy 80 miles of fuel left.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 16, 2025
