B_Sjulestad
Jun 17, 2015Explorer II
rhagfo wrote:
I will play devils advocate and ask WHY? 250 miles or so do you have a short bed and small tank? It is basically a down hill tow, you should get at least 10 mpg, if not 12 mpg. I could get there with an easy 80 miles of fuel left.
That said, you do realize that all service stations get filled by double tankers. They fit just fine, you just need to look ahead as you approach.
True but I will be going from Grand Junction which is uphill, not sure what kind of mileage I will get so I'm trying to plan ahead just in case. The tanker trucks do not have to go through the islands,
they usually fill at the end of the drives/lots.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
