Old-Biscuit wrote:
B.O. Plenty wrote:
HappyKayakers wrote:
Get one of these: http://www.amazon.com/Valterra-T58-Twist-On-Waste-Valve/dp/B000BGHYJS
Make all your hose connections first, then pull the handle. Quit worrying about what's left over in the pipes that may spill out as soon as you remove the traveling cap.
First thing I bought for mine...right after I got a shower draining it for the first time! Best thing to put on EVER !!!
B.O.
I installed another 3" drain valve in horizontal section of main drain line just before the end cap. No storing of the extra valve (twist on) or having to put it on/take it off.......twist on would stick out/down to far to leave on.
Mine has been hanging on for 25,000 miles. I put it on so the handle faces the front. Never had a problem with it coming loose or moving. No plans to take it off ever. If it ever loosens up I'm gluing it in place!
B.O.
