Reelay
Jun 06, 2015Explorer
shore power
If you keep your trailer plugged into the truck while using shore power does this create any problems for the charging system or any other problems? Thanks in advance.
rskeans wrote:I think you will find that Chevy (and of course GMC) does NOT disconnect the trailer when the ignition is off.
Dodge does not disconnect the 12V from the 7-pin like both Ford and Chevy.
rskeans wrote:
Yes, to a point. I'm not sure that the charge wire will allow enough current to charge the trailer batteries in a reasonable time. When you are driving the highway you are charging the trailer batteries. I don't know if you want to let your truck fast idle for a period of time to charge the trailer batteries. Sounds like you are a candidate for solar.
rskeans wrote:
Dodge does not disconnect the 12V from the 7-pin like both Ford and Chevy. So essentially the trailer is charging the truck battery. I had a situation where I was long term with a Truck Camper on my RAM. I disconnected the 7-pin in that situation. For short term, like 1-2 days I wouldn't worry about it.
