slide gasket coming loose
bapple
We have noticed that one of our slide gaskets inside is coming loose. What can we use to glue it back in.
Thanks
3 REPLIES 3
cpaulsen
I used Gorilla Glue.
cpaulsen
bapple
Thank you for your help. We ended up at an auto store and they recommended a glue. Here's hoping it works.
SH
A picture would be helpful. So many different types of seals. Some clip on, others snap on, some have a self-adhesive strip and still others are simply glued. If you are positive you have a glued type of seal you can use 3M Supper 77 Adhesive Be very prudent using it...it sticks well and not easily removed if you tack in the wrong place.
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo ๐Ÿ™‚
