slide out and landing gear stalls when retracting
shug2323
I hope someone can help...The RV shop seemingly has tried everything.. I own Mobile Suites 5th wheel. When I retract the living room slide out, it stalls. I hear a click as if there is a reset button and then it works.. Then it stalls again. I wait 30 seconds and can continue to retract.....I have the same issue when retracting the landing gear. It stall, I hear the 'click' and 30 seconds later it's working again ….Repair shop tried putting in a new control panel...new batteries...new switch......problem still continues...….Does anyone have a clue/hint/suggestion ? Thanks
PS....I have no issue when we let the slide-out out or let the landing gear down...It is almost like there is a power surge that is causing a fuse to blow and get automatically reset.....The fact that it is both the landing gear AND the slide-out seems like a clue
31 REPLIES 31
newman_fulltime
They put in a new relay? Motors take more amps going up and in than out and down .take a battery isolate the curcuit see if its at the pump or the wire itself.
( if it be my first guess i would say yhe motor on the pump is going bad on one side of the windings )
donn0128
Not really except to say weak battery. That is the only common factor.
