MC63
Dec 29, 2014Explorer
Solar charging batterries
Wanting to add a solar battery charger.
I have searched and searched Google about this and didn’t find the answer to my dilemma.
I found a couple of forums that mentioned a potential problem with the way a trailer is wired on the inside.
In my toy hauler I have two 6V batteries wired in series to supply 12V to it.
http://www.trojanbattery.com/pdf/datasheets/T105Plus_Trojan_Data_Sheets.pdf
I wanted a solar charger to be hooked up to them to maintain the batteries when in storage and ALSO when in use camping. I thought (and what I found on Google confirmed) that all I had to do is connect the positive from the charger to the positive battery out to the trailer and the negative from the charger to the negative out to the trailers frame. Ignoring the + and – battery terminals that are connected together. With the solar panel hooked up the panels controller says it is charging but the battery monitor inside the trailer shows discharging and my gas alarm beeps. I am going to try the solar charger on the batteries with the batteries Disconnected from the trailer to see if this works but I really want to be able to have a solar charger connected when the trailer is in use camping. Any suggestions??????????
My solar panel is up to 18 watts
load charge 8 amp max
controler cut in at 13V cuts out at 14.2V
Thanks in advance.
Thanks in advance.
