- RCMAN46ExplorerAs for the Ubolts if there is enough bolt I recommend double nutting them.
- rjsurferExplorerWhile your down there checking the bolts on the springs don't forget the nuts on the top of the U bolts that hold everything together.
After one broke free and had one of the axles pointed in the wrong direction I checked them all and many were loose.
Very common problem.
Ron W. - The_Mad_NorskyExplorer
Wood chip wrote:
My trailer was repaired today and OutdoorRV came through with the quick approval to have it repaired near my house. The hangers and bushing were ok and new bolt was installed. Took about an hour with 2 guys. I re-tightened all the bolts. I will do this annually moving forward. Thanks for replys.
Love a story with a happy ending.
Good to hear, and good for you! - othertonkaExplorerThanks for posting the results
- Wood_chipExplorerMy trailer was repaired today and OutdoorRV came through with the quick approval to have it repaired near my house. The hangers and bushing were ok and new bolt was installed. Took about an hour with 2 guys. I re-tightened all the bolts. I will do this annually moving forward. Thanks for replys.
- minnowExplorer
64thunderbolt wrote:
OK, who has the popcorn?
Those of us with a little common sense and who are not related to that kid with a finger in the dike, have already left the theatre . - 64thunderboltExplorer IIOK, who has the popcorn?
- laknoxNomad
PRodacy wrote:
RCMAN46 wrote:
The bolts on my trailer not only had the knurled portion on the head end but on the thread/nut end the threaded section is smaller diameter than the body. This gives a shoulder for the nut to be torqued against and control the distance from the nut to the head.
My shackle bolts are not anything you will find except at a trailer supply or someone that carries shackle bolts. They are a special single purpose item.
Mine look like these.
Wet Bolts
I had not heard of wet bolts before. Can someone explain how they work? The link didn't provide any information. Do they just provide a layer of grease between the bolt and sleeve? Is there a grease seal somewhere on them? Zerk fittings? Thanks. Always good to learn new things.
The kits I've seen have greasable bolts (a zerk fitting on one end, drilled lengthwise and a cross-hole in the middle), new bronze bushings and heavier (thicker) shackles. They greatly increase suspension life.
Lyle - PRodacyExplorer
Wet Bolts
I had not heard of wet bolts before. Can someone explain how they work? The link didn't provide any information. Do they just provide a layer of grease between the bolt and sleeve? Is there a grease seal somewhere on them? Zerk fittings? Thanks. Always good to learn new things. - RCMAN46ExplorerThe bolts on my trailer not only had the knurled portion on the head end but on the thread/nut end the threaded section is smaller diameter than the body. This gives a shoulder for the nut to be torqued against and control the distance from the nut to the head.
Wet Bolts
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
