wrasse
Jan 27, 2014Explorer
TT or 5th wheel Toy Hauler Safest with 1ton SRW TV?
I currently have a 2011 SRW Ram 3500 Megacab with cummins 6.7.
DRW is not an option for us at this time. Trying to see if TT or 5th wheel would be better option.
According to factory specs...
My 2011 SRW Ram 3500 Megacab has payload of 2600 lbs, max travel trailer rating of 13,350 lbs. Unfortunately, Dodge does not list a separate rating for 5th wheel towing.
My tires have been upgraded and are larger 18" E rated with 3900lb load capacity.
My truck also has an upgraded curt 18K hitch.
I have towed 28ft boat weighing 12K plus on trailer and it does great with handling it, downhill on the mountains were cake with the exhaust brake.
Travel trailer toy hauler option that we like.
It has these specs
Impact Fuzion 303 Travel Trailer Toy Hauler
Dry weight: 8834 lbs
Hitch Weight: 1300 lbs
GVWR 13,000
http://www.keystonerv.com/impact/
We would need a large wd/sway hitch setup for this.
But at nearly 35 feet end to end, this would be pretty long load behind us.
We also love these 5th wheel toy haulers in the 35-36ft range but they are all quite a bit heavier in terms of GVWR.
Voltage V3200 (Dual Axle)
Voltage Haulers Model 3200 Floorplan
Unloaded Weight 12,994
Hitch Weight 2,599
GVWR 16,500
Impact 311 (Dual Axle)
Unloaded Weight 11,095
Hitch Weight 2,790
GVWR 16,500
Thunderbolt XLR 380AMP (Tri Axle)
Thunderbolt Toy Hauler Fifth Wheel by Forest River
Unloaded Weight 13,475
Hitch Weight 2,323 (lightest, probably b/c tri axle setup)
GVWR 18,000
Out of these three, which of these options would be the safest to tow for us?
We would use it 6-7 times per year, traveling between 300-1500 miles.
It has these specs
GVWR 13,000
Hitch Weight 2,599
GVWR 16,500
Hitch Weight 2,790
GVWR 16,500
GVWR 18,000
