โMar-28-2017 01:50 PM
โMar-29-2017 12:02 AM
โMar-28-2017 09:30 PM
time2roll wrote:rhagfo wrote:Those are not greasable bolts.
Never Fail Bushing & Wet Bolts
โMar-28-2017 08:01 PM
โMar-28-2017 07:44 PM
โMar-28-2017 07:03 PM
rhagfo wrote:donewithtrucking wrote:
Replaced all my suspension spring and rocker bushing in 2015. All were what they call" wet bolts" with plastic" so called" bushings. Great now I can grease them yearly and they will last a long time. The first year most greased very easy. This year unable to get any grease to go in. So I guess I should just let them ware out!
Not sure the advantage of putting wet bolts in with plastic/nylon bushings. Was it just wet bolts, or the new wet bolts with 1/4" thick HD shackles?
The Mor-Ryde Kits come with the HD shackles, wet bolts and bronze bushings.
โMar-28-2017 06:50 PM
โMar-28-2017 04:34 PM
โMar-28-2017 04:28 PM
โMar-28-2017 03:59 PM
โMar-28-2017 03:06 PM
โMar-28-2017 02:44 PM
โMar-28-2017 02:33 PM
rjxj wrote:
Often times when wet bolts are used, bronze bushings are also used. You might try lifting the rig so that the axles drop and try greasing again with the pressure off everything.
โMar-28-2017 02:04 PM
