avvidclif1 wrote:
taken wrote:
dpam wrote:
Hey Taken, sorry to have hit a "sore spot". So, what brand of half ton do you tow with?
No sore spot at all. Just have info that others don't seem to have. My truck and trailer is in my sig along with a picture for your viewing pleasure...
I'm curious how your trucks numbers match up to the TH you have. That trailer is well into dually territory and probably F450
395AMP
Hitch Weight 2647 lbs.
UVW 14516 lbs.
GVWR 21000 lbs.
CCC 6484 lbs.
Fresh Water 150 gal
Those are empty weights. How much does yours weigh ready to go out camping. Scale weights please.
Under 3k pin without anything in the garage so at but not over my GVWR of the truck (11.5k) as it weighs 8500 ready to tow. 16k ready to camp. So, also within my numbers. If I load the garage (pin goes down) or fill the water tank to capacity, I stay within my truck's GVWR, GAWR, tire ratings, and only go over GCWR which is not a concern for me. Thanks much for your interest in my weights and truck recommendations though. It's good to know my fellow RVers care...
By the way, I see you posted your pin weight is at 3420. I think you have more to worry about than me. Is your dually or 450 on order? I'm worried about you...
Edit: Just re-weighed ready to tow with garage empty. Even better shape than I thought!
