wiring 2007 fleetwood nitrous hyperlight toyhauler
debraindi
In the cabinet above the stereo are four bare wires. Two wires are #6 and two wires are #12 size. Our problem is the batteries will charge with the 4000 watt onan using shore power the inverter will not charge the batteries. Any ideas would help,
Thank you
Debraindi
2013 LML Duramax
2015 311 Keystone Impact
200q 24 partycraft 150 mercury
Time out motor cycle trailer
2009 Harley RG 575 cams thunder-max tuned
1970 350 JD crawler loader
3 REPLIES 3
debraindi
The stereo system was replaced, Thanks for the information Cale. Its all good now I will add a few 1 by 2 s with plywood and get more storage, Thank you
2013 LML Duramax
calewjohnson
Do you have a Kenwood amp up there? I have a 2007 Nitrous (the 23 ft). My cabinet above the radios has only an amp for the stereo system.
Cale
TV: 2015 6.7 F350 CC LB 4x4 DRW with 14k GVWR option (4.3 gear), 98 gallon aux tank installed by Transfer Flow
New: 2014 Voltage 3950
Traded: 2014 Outback 323BH
Still Have: 2007 Fleetwood Nitrous 23ft Toy Hauler
debraindi
I looked on line and found the manual for wfco 45 amp converter and found that if the batters where connected in reverse polarity it blows the 2 30 amp, Sure enough one more problem solved. Im confused about the hot number 6 wire inside the rig above the radio. Could it be for a battery?
2013 LML Duramax
