Nov-17-2016 08:24 PM
Nov-23-2016 07:45 PM
Nov-23-2016 04:34 PM
ro_sie wrote:No Oxygen depletion or Carbon Monoxide is created by electric heater or heat pump.
2oldman, all I can tell you, as I wasn't there, is that is what was said at the time. They said the room they were sleeping in was closed up as air tight as they could get it, and they all died. It was mid Missouri in the coldest of winter and for some reason or other they had lost their heat source. All I know is, I am very careful with space heaters. Take it as you please. I just know I lost someone who was a very dear school friend.
Nov-23-2016 04:29 PM
Nov-23-2016 04:17 PM
ro_sie wrote:It likely could not have been an electric space heater, unless it started a fire. It was most likely a portable propane heater for which there are many cases of CO fatalities every year.
Nov-23-2016 04:24 AM
Nov-22-2016 09:15 AM
ro_sie wrote:I didn't know electric heaters used oxygen.
... she and her husband and two children were using a portable electric heater for heat. Apparently all the oxygen in the room was used up...
Nov-22-2016 09:00 AM
Nov-21-2016 06:44 PM
EsoxLucius wrote:
If possible you could replace your furnaces with efficient and quiet Propex HS2800 furnaces.
http://www.propexheatsource.com/heaters/hs2800-furnace/
Nov-21-2016 06:41 PM
EsoxLucius wrote:mchero wrote:Note what the manufacturer says:
Looking at this model;
http://www.landmsupply.com/department/home-improvement/heating-and-cooling/propane-heaters/ventless-...
What's your thoughts?
RMNot for use in bathrooms, bedrooms, or recreational vehicles. 4,500ft high altitude restriction. Propane cylinder must remain outdoors.
Nov-21-2016 05:56 PM
Nov-21-2016 05:51 PM
Nov-21-2016 05:46 PM
RM
Nov-21-2016 08:17 AM
Nov-20-2016 06:22 PM
2gypsies wrote:
We used the Empire propane heater for 16 full-timing years with lots of boondocking (Quartzsite, too) - and even if we were plugged into electric at a RV park.
The RV furnace is inefficient, noisy and cycles on and off with heat and cold.
The propane heaters give a constant warm heat. They are awesome!
They are used by many, many full-timers.
