klutchdust's avatar
klutchdust
Aug 18, 2014
09 E450 stuck in park
Just thought of this and giving a heads up. original owner stated that once it would not come out of park after starting. He jiggled the stop light switch
under the dash near brake pedal and then things were ok. On our 2375 mile road test from Minnesota to Ca. we were 75 miles from home
I pulled over to take a break and it did it again. Old school vehicles you didn't need to depress the brake pedal to move the gear selector.
This might save someone a huge headache.
  • I've had this happen a couple of times and apparently blundered my way out of the problem. This is a VERY useful thread; thanks to all.
  • I have a 2008 Ford e450 and this same thing happened to me a couple of months ago. Unknowingly, I had been under the dash connecting a wire for my rear camera and accidentally pulled off the wires to the switch that controls the disengagement of the gear lever. This switch has nothing to do with the stop light switch, but is a separate switch which has a push button which is depressed when the brake pedal is in the upper position. When you step on the foot brake, the button is released, enabling the gear shift lever to be taken out of park. This feature is in almost all vehicles to ensure you have your foot on the brake when putting the car in gear. Check that the wire bundle going to the switch has not pulled away. The switch is directly above the brake pedal.
  • Another angle to this, if you ever blow the fuse for the brake lights you may not get out of park for similar reasons.
