flyfishingfool's avatar
Mar 23, 2015
12 v lights
I blew the fuse for the 12v bedroom and bathroom lights and cant find the fuse.I checked every fuse on the dash and under the hood and nothing.Its a 2013 bounder classic 36R I know there is another fuse box but cant find it,any ideas?
  • wa8yxm's avatar
    wa8yxm
    Fuses under the dash like the fuses in the dash on my care are AUTO (Chassis) fuses.
    Fuses under the hood likewise (And my car has those too)
    Fuses in the 12volt power distribution panel which is either part of the combined 12/120 volt power distribution center (And often converter) or near the 120volt distribution center (Breaker box) are for HOUSE (Bedroom lights) circuits.
  • Thanks everybody just found it built into wall of pantry against floor had to lay on floor with flashlight to find it.Of all of the places they could have put it this place is not a good one.
  • Mine are in the bedroom near the 120V AC breakers. The fuses in the dash and under the hood are for chassis systems. The house system fuses are separate.
  • Usually behind the same panel that all of your 120V AC breakers are under.
  • Fuse panel is probably at or near the converter. Find that and you will likely find the fuse panel
