Apr-11-2014 11:07 AM
Apr-21-2014 04:31 PM
Apr-21-2014 12:36 PM
Apr-17-2014 06:55 PM
tenbear wrote:
Have you checked for a fuse or circuit breaker in the wire from the battery to the converter?
Apr-17-2014 06:54 PM
maillemaker wrote:Yes, the interior lights work when plugged into the shoreline. They do not work when not hooked up to the shoreline.
Lights do not work with the battery. I tested the battery it was bad. I know have a new battery in and still no lights when the shoreline is not hooked up.
So...it sounds like your converter is working because your 12VDC items are working when you are plugged into shore power.
But it is strange that they do not work when on battery power with the new battery.
My guess here is that the converter is bad and is not switching between shore power and battery power.
Steve
Apr-17-2014 12:53 PM
Apr-17-2014 11:15 AM
Apr-15-2014 01:01 PM
Apr-15-2014 12:59 PM
tenbear wrote:Harvey51 wrote:I am not able to run the water pump and the furnace will not run. I do have interior lights,
Lights work means 12 V system is working. That rules out batteries and converter problems. It just leaves fuses, doesn't it? Best to use a meter, ground the black lead and use the red to see if there is Voltage on the outgoing side of each fuse.
Do your lights dim when you try to run the water pump or the furnace?
Apr-15-2014 12:57 PM
maillemaker wrote:
Almost everything in the RV coach runs on 12VDC. Your lights and water pump run on 12 V. Your furnace runs on 12VDC.
This is true whether you are plugged into shore power (110VAC) or not.
Your refrigerator probably is able of running on 110VAC or propane, but on propane will probably require 12VDC. Your refrigerator might also run on 12VDC. Some are two-way (propane/110), some are three-way (propane/110/12)."
We can operate the refrigerator from the shore line and from the propane. I have had no issues with the refrigerator.
Your microwave and air conditioning run only on 110VAC.
"So. To see if your shore power is hooked up right, the first thing I do is try to run either the AC or the microwave. If those things work, you've got 110VAC."
The A/C and Microwave works when the shoreline is plugged in.
"Next try your 12VDC accessories while you are plugged into shore power. This takes the battery out of the picture. If your internal lights work, you've got 12VDC at least there. So I would suspect fuses first since clearly your converter is working."
"If you find that on shore power all your 12VDC accessories work, but on battery only the lights work, it may be that your battery has enough power to power the lights but not other higher-load accessories."
Your furnace has a "sail switch" in it. Before the burner turns on the fan will come on and air will start blowing through the furnace. If this does not happen with enough force to activate the sail switch, the burner will not turn on and the furnace will shut down. This is to prevent the burner from overheating/catching fire if there is not enough air blowing through it to cool it off.
Steve
Apr-15-2014 04:35 AM
Apr-14-2014 09:56 PM
Apr-14-2014 01:30 PM
Apr-14-2014 07:40 AM
Apr-13-2014 05:58 PM
