mikeyp
Feb 19, 2015Explorer
12 Volt Power Problem with Bounder
Have a spooky new problem - my Fleetwood Bounder is plugged in here at the campground for the month. The 110v current is solid and house batteries fine and pretty new. About on average once a day, totally intermittently and with the regular 12v stuff running (frig, hot-water controller and 1-2 lights) when we switch on a new light (12v) the entire 12v system stops. Everything goes dark. Except the 110 v (TV, computer, etc) lines. They stay lit. So its not the shore line. The converter seems to keep humming though I have not been quick enough get outside around back and to check it. The outage last varyingly 5-30 seconds. Then for no reason - everything comes on, fine and all systems go. No brown-in - just instant spontaneous start. Anyone have any ideas? I did buy a back-up converter with the expectation of needing it to swap in - but don't want to if this is coming from something else. PS - it always happens exactly when we turn on a 12v lamp - different ones each time. Thanks. Mike P.
