mikeyp
Feb 21, 2015Explorer
Its a 1999 Gas 36S. It happened again last night when I went into the bathroom and turned on the light. I heard a distinct loud CLICK when it went out, and a CLICK ten seconds later when it turned itself on. Seemed to be coming from the main breaker panel box above the refrigerator. But I searched and saw nothing in there that might do it - only the 12 v fuse board and the 110 breakers panel and no other suspects. Is there anything mounted behind the main front surface of the panel that would require removal to access? I did try cycling the battery shut off switches on the convenience panel next to the door as you suggested. Those loud clicks were different and came from somewhere under the dash by the drivers seat, or on the firewall just in front of it. Couldn't tell which. Thanks. Mike P.
