BobR's avatar
BobR
1991 Ford 460 Cruise Control Cable
The cruise cable, E7UZ9A825C, broke and I have been unable to find a replacement through Ford or salvage yards. I was hoping someone might have a spare or was in a similar situation and came up with a suitable alternate for this part. Also, how does the cable attach to the vacuum servo? Any suggestions or pictures greatly appreciated.
  • Thanks guys. NAPA and fordparts.com were unable to help and I was hoping someone on the forum might have a spare no longer needed.
  • Check and see if there is a place that can make a cable for you. In the Bay Area there used to be a place called California Push Pull that made throttle cables and other sleeved type cables. Also, Check with www.fordparts.com to see if they can find it for you. Good luck.
    Bob in Calif.
  • Have you tried a NAPA autoparts store. I have never had a problem getting parts for my then 87 Allegro or my 79 Bronco.
