rgnprof
Jun 14, 2016Explorer
1993 Ford E350 Vacuum and A/C question
Haven't been on here much lately - too many other things going on...but, we took the RV out last week for the first time in a year and had a great, rather uneventful trip - except for no cabin A/C. Not a huge deal, but I'm in the midst of fixing it right now. The system was EMPTY - so I tried to draw a vacuum, just to see what I had. I really think the problem had to do with the schrader valves, but I'm not sure. I pressurized the system with compressed air (yes, I know nitrogen is better and I know about the moisture issue - I used a filter and I knew I was changing out the drier - at least - when I was done anyway. Didn't find any huge leaks after spraying around and the vacuum got down to 29" or so and when turned off, held steady for more than 10 minutes.
Pulled the orifice tube today and it was covered in really fine, almost dust like metallic particles (they were attracted to a magnet)- pretty clogged up. I'm assuming my FX15 compressor has died - I have a new one (FX10) coming tomorrow, as well as a new condenser. My question is should I replace the evaporator as well? And how concerned should I be about the hoses? I see no signs of oil/leaks and I am having an impossible time finding any replacements for this van chassis...the line from the compressor to the condenser has a muffler installed in it and I've read that you can't really flush those. But, if I get the hose out to where I can turn it upside down, do you think I can run some flush through it? I am planning on flushing the evap and all the hoses - installing new compressor, condenser, drier and orifice tube and going back with R12.
One other question - in taking the drier off the passenger wall, I had to remove the vacuum reservoir. I noticed that nothing was hooked up to it - no hoses running to or fro..? Been like this since I've had the coach (6 years) - should I be concerned about this?
Any other advice/ideas?
Thanks,
Ryan
Thanks,
Ryan
