Gjac
Jan 30, 2018Explorer III
Kwikee has an excellent troubleshooting manual online, and with a multi meter you can check the switch, motor and control box. You said that the switch is good, you can run 12v directly to your motor to see if that works, if so that leaves the control box. Being a 1998 you probably won't find a replacement at a dealer if so the tech will say you need to buy a whole step unit. The control box has 2 relays inside if you look closely and see a burned relay you know what the problem is.The relay is less than $4.00 at Digi-Key. Hope this helps,let us know how you make out.
38,705 PostsLatest Activity: Jan 14, 2025
