Steps will not close. Door magnetic switch is functioning. Light under steps remains on always. When measuring voltage at the magnetic switch I get 0 volts when door is open and 0.6 volts when door is...
Try these people Colaw At some point in time the magnetic door switch was changed from normally open to normally closed contacts. Or was it the other way around! Make sure you get the correct switch! Colaw gave me both!
