Triker33
Feb 03, 2017Explorer
Mounted under the Power Gear touch pad there is a control panel that has fuses. Check for blown fuse.
Fuse replacement for manual control touch pad
XF1 = Power unit motor starter solenoid fuse 1.6 AMP.
XF2 = Dump solenoid fuse 3.15 AMP.
XF3 = Left rear jack solenoid fuse 3.15 AMP. (RR)
XF4 = Right rear jack solenoid fuse 3.15 AMP. (CR)
XF5 = Front jack solenoid fuse 3.15 AMP. (F)
REMOVE: To remove fuse, use needle nose pliers and pull fuse straight out
INSTALL: To install fuse use needle nose pliers to insert the fuse making sure pins on fuse enter receptacle correctly
38,705 PostsLatest Activity: Jan 24, 2025
