BobcatDriver
Feb 03, 2017Explorer
2000 Bounder D.P. 39 Z house battery connections help
A friends RV house battery connections need to be restored to factory as built. The problem is a local "expert" previously replaced the 4 house batteries with 2 12 volt batteries that I found dead. The house 12 volt lights stopped working then. I have installed a new pair of 6 volt golf cart batteries, in series, in the house charger/inverter system. This subsystem seems to be correct and indicators show it working. The connection to chassis ground was lost. I believe, resulting in no 12 volt lights and possibly other 12 volt devices. The other things will be project no. 2 after the lights are operational.
#1 where and how was the house battery bank grounded to the chassis at the factory? I do not find an unused black battery cable in the area.
I found 2 dangling red battery cables in the house battery section that head over the transmission then go toward the front, on the road side, destination unknown.
#2 what might the 2 heavy red battery cables be connected to up front? Generator? Other? Should they attach to the house 12 volt system?
