Marv_Hoag
Feb 01, 2017Explorer
2000 Monaco 12 volt replacement bulbs
My Monaco has ceramic sockets for small 2 prong 12 volt bulbs. I have tried to find replacement bulbs, but they fit loose in the ceramic socket. The center prong on the original bulb is larger than the replacement bulbs from the local RV store. Has anyone else had this issue and found the correct replacement bulb? Hard to make something loose work correctly.
The difference in size ( the part that goes into the socket ) is almost not noticeable, but really really affects the fit in the ceramic socket. The part that goes into the socket is flat.
