- GjacExplorer IIIWhen you say "steering kicks back" do you mean it pulls to the left or right when brakes are applied?
- rgatijnet1Explorer IIIOne or both of your discs/drums could be "glazed" from the heat and in spite of having new pads, the braking is uneven.
- DrewEExplorer IIIt could also be a brake not releasing (a sticky caliper if disc brakes, or the equivalent for drum brakes), which would make it pull all the time to one side but feel like it's pulling to the other side when the brakes are applied by comparison to the new "normal."
- midnightsadieExplorer IIboth, and if they got that hot you should change the rubber connecting hose,and the fluid.
About Motorhome Group
38,707 PostsLatest Activity: Feb 17, 2025
