Dollfundeb's avatar
Dollfundeb
2005 Holiday Connecting Rod Failure
Wednesday afternoon we were leaving out of Socorro, New Mexico while accelerating from 45 to 55mph we experienced a loud explosion and looked in the rear mirror to see a huge amount of smoke and as my husband always travels with the Aladdin system displayed in the main engine page he looked down and saw there was only 3psi of oil pressure after noticing that and pulling over it was then that the alarms went off. Please note the alarms did not go off prior to the loud explosion. It was after he said wow we only have 3psi of oil pressure and made his move to pull off to the side of the road immediately. Went to the back of the coach and found a huge oil puddle. Looked under the engine to find a large hole in the side of the oil pan. We were towed to Statkus Engine Service in Albuquerque New Mexico. They downloaded the computer and the code was Oil Pressure low and it was recorded for 14 seconds. No alerts or alarms prior to event. This is a 2005 Holiday Rambler Scepter it only has 23057 miles on it and it was running exceptional until that moment. We checked the Cummins recall and this s/n on this engine falls just outside the range of s/n that Cummins calls out. According to the owner of the shop that checked all of his resources no one will touch this engine - why I do not know??? The owner also seems perplexed that no one will touch it. The owner also told us that in his 41 years of business he has only seen this happen 3 or 4 times. He also wants to cut the rear fiberglass fascia apart and cut the rear cross member and hitch out of the coach to get the engine out - is this how you remove the engine out of this coach??? We would really appreciate anyone and everyone help and advice on this. Thank you so much in advance
