Sort By
- ejerniExplorerWe never thought about it being the mirrors! We will try it next week.
Also if that doesn't work, the foam inside might work if it is the hood.
Thanks so much! - cochise49ExplorerWhen we bought our previous RV, a 2005 Cross Country, we also thought the hood was howling. Turned out it was the gross adjustment of the mirrors, They worked OK with the remote but had to use the included allen wrench outside to reposition the distance from the coach. Took a few miles to get it just right.
- MountainAir05Explorer IIMaybe some foam tape around the inside lip of the door. If gen is on a table it might be moving around. lube the bearing with grease and see if that it also. You also could clamp it down.
About Motorhome Group
38,720 PostsLatest Activity: May 18, 2025
