2008 Country Coach Affinity --service checklist?
rafo
I have a 2008 Country Coach Affinity. Great coach, great physical condition. But now it is 6.5 years ago (purchased early 2007) and has not been used in the last year or so.
I am planning on a long trip to Alaska in April/May and a few short trips in the next few months.
What should I get serviced and where? The coach is in Las Vegas. I feel that I should get the engine oil/coolant/etc done by a Freightliner or someone that services trucks (it has a Cummins engine) and I also think it is time for change all of the tires (again, probably a truck shop?)
Can someone recommend a truck shop? Do these guys know what the checklist is for servicing this coach? Does anyone have access to this checklist?
I probably need to also change instahot coolant, generator oil, ??.
Should I change: engine batteries and the coach (deep cycle) batteries?
17 REPLIES 17
Sully2
Want a short trip? Drive it up to CC in Oregon and cruise about in your toad as CC themselves does the servicing
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
smlranger
Agree with George's checklist above. If you can find a Cummins CoachCare certified shop in your area, they should be able to do all of that except the tires. Most any commercial truck tire shop can replace your tires.
I'd also replace my serpentine belt on the engine just for good measure. We just got our 6 year old Allure and I did all the stuff on George's list along with new serpentine belt and had the differential lube changed.
2019 Grand Design Solitude 384GK 5th wheel. Glen Allen, VA
gsander1
You should not need to change the media in your AquaHot.
Engine
Change oil and filter
Fuel filters
Coolant filter
Air filter
Air drier dessicant
Hydraulic filters(3)
Transmission
Filters changed
Fluid changed if not Transynd
Hydrohot
Fuel filter
Nozzle replaced
Generator
Oil and filter
coolant flush and fill
Air filter
Load test both chassis and house batteries
Now you're good to go.
Good luck.
George in Birmingham, AL
03 Country Coach Magna
