GollyCollie
Sep 23, 2013Explorer
2013 Leprechaun water leak problems
My wife and I bought a new 2013 Leprechaun 317SA that we like a lot except we have very bad water leak issue in it. The front cap on our unit, and apparently on a lot of 2013 Leprechauns, was mounted improperly and it allows water to leak in and collect inside he front cap. This water that pools in the front cap then spills over into the hollow bunk deck and goes from there. I discovered the problem when I turned a corner and water showered down on my head! The dealer has made several attempts to correct the problem over the past 4 months, but each attempt has been a failure. Currently they have the front cap totally off of my unit so they can replace the bunk that has been damaged by the water. We are waiting for the bunk from the factory and they are giving me an estimate of 3-4 weeks before it is here. Once the dealer pulled the front cap off they found that the cap was mounted with non-water resistant, double face tape and then simply sealed around the edge with silicon. if the silicon seal is breached in any way, water comes right in and collects in the cap. According to the dealer, they have several more Leprechauns on their lot that are the same way and have water leak problems. This tells me that there must be a lot of them out there.
I think that my dealer is doing the best he can do to make my coach right but I am getting very frustrated with it. I am making payments on an RV that I can't use. I also know from sad experience what water can to do a motorhome and don't want to repeat it.
I would be very interested to hear about anyone else with a new Leprechaun that is having water leak issues so we can compare notes. Maybe I can help you with what I have learned too.
