twmarshall's avatar
twmarshall
2013 Thor Challenger 37KT Inverter
Does anyone have a picture of the Inverter location on a 2013 Thor Challenger 37KT? My outlets running through the inverter will not work with shore power, only run for a minute on inverter. Power is coming from the 120 breaker, the outlets power up for a minute with the inverter remote on but then loose power (remote light stays on), the batteries are charged (12.86 VDC) and the converter is putting out 13.46 VDC). I need to check the AC power at the Inverter but can’t find the **** thing. I’ve looked in the cargo compartments, at the batteries, and behind the fireplace...
  • Thanks all. The tip of under the nightstand led me to see the telephone wire that connects the remote to the inverter, that led me to a false compartment under the head of the bed where I finally found the inverter with a tripped breaker and the transfer switch. Problem solved!
  • Ck under the draw in the night stand closest to the bathroom
  • A few places to look, many RV's that place the inverter inside the coach use a screen or lovers to allow cooling. Look for a place inside the coach that is not an accessible cabinet, but has a vented or louvered door.
    On my coach, the inverter is mounted to the ceiling in the main bay, hard to see.
    Lastly, many manufacturers mount their inverters very close to the house batteries, as they need large 12 volt cables that are expensive to run.
  • A little thought invoking process
    Where is the breaker panel
    Where is the first outlet that does not work, aka closes to the breaker panel
    Your inverter is some where between those two points,
    Perhaps hidden behind a cabinet wall, or behind the breaker panel
