craigspeer2001's avatar
Aug 16, 2013
30 amps too 50 amps is it posssible
I have a 95 winebago brave and i upgraded the front ac from a 7500 watt too a 13,500 the generator will run both acs but when you plug into shore power with the same 30 amp plug you use on generator it want run both acs. I would like to keep it where the generator runs both units so what do i need todo correct the shore power deal or is it just what it is.
