John_Joey
Nov 17, 2013Explorer
Is that year carb'ed or EFI? If carb'ed wasting a $2 can of WalMart carb spray isn't going to hurt a thing and will make things look nice and clean.
Also an old trick is to lightly mist over the intake, if the engine speeds up then you are running lean (could be varnish in the bowl, or out of adjustment.) Also spraying lightly around the intake manifold will show a leaking gasket by again gaining rpm's
