John_Joey
Nov 27, 2013Explorer
That's great news Geocritter, the more you use it the better it will run. Like I said in a prior post my rig didn't "break free" for well over a thousand miles of constant use.
BTW, I swapped out the fuel filter yearly for the first three years. They are cheap and easy and the problems with a bad filter on the road can be a real PITA. Also if I sat for much more then 3 months I would park with a 1/4 tank and Seafoam it. If I didn't do that it took a few hundred miles before the engine would kick up her heels.
On Edit:
On your starter problem. Make sure your ground strap is in good condition and has clean ends. It should be located by the alternator.
On Edit:
