โSep-10-2014 04:05 PM
โSep-12-2014 03:45 PM
dodge guy wrote:I wonder if Mike from 5Star would post here about his?
OK, On some newer vehicles recently (2013 and 2014) the manuf. put a code in the PCM so that when a non-manuf. tune (read;aftermarket tune) the PCM will store that code and it is not eraseable, meaning it will be there for eternity! when you bring a vehicle in for driveline service they will scan for codes and if that is in there...bye bye warranty! Yes the tuner will save your stock tune, but the aftermarket tune has it`s own VIN. so when it doesn`t match the manuf. VIN the PCM flags it and saves the code.
Now, once it`s out of warranty then you can do whatever you want! and that is what I would do. tune it once the warranty expires!
โSep-11-2014 08:31 PM
โSep-11-2014 07:51 PM
โSep-11-2014 07:25 PM
โSep-11-2014 04:38 PM
โSep-11-2014 03:33 PM
โSep-11-2014 02:59 PM
dodge guy wrote:smacdiesel wrote:
Does this setup effect the Ford warranty?
Probably? And i believe the new PCM's will save a code (non eraseable) in the memory that shows it had an aftermarket flash (tune). Once it's out of warranty is when i would flash it, then I wouldn't even worry about it!
โSep-11-2014 02:50 PM
โSep-11-2014 01:07 PM
โSep-11-2014 10:35 AM
โSep-11-2014 10:21 AM
hanko wrote:Bumpyroad wrote:
so if I get this I have to spring for the high test $$$$$ fuel?
bumpy
No it tuned for 87 octane
โSep-11-2014 07:16 AM
bumpy
โSep-11-2014 06:32 AM
โSep-10-2014 06:16 PM
hanko wrote:dodge guy wrote:
Yes 5 star is the best for the V-10. I have it on my 02 and it was money well spent. I got it for the improved shifting strategy, which it does very well! a side benefit Is that I gained almost .5mpg towing! wish I would`ve gotten it years ago!
I`m assuming you have the coach in your sig? 2014? I was wondering how well the stock V-10 and 5 speed performed? glad it is working out well!
I was rather surprised that it hauled as well as it did, i weigh 22,500 loaded. Its in getting a banks power pack installed as we speak. Mike at 5 star custom tuned it for the power pack. The lack of downshifting is what impressed me. With the new fuel parameters set, it really rumbles
