50 AMP and plugging in at home
Timothy2001
Although new to this, I strongly suspect that a coach that has 50 AMP service may not be able to run A/C in the Texas heat on an standard outdoor extension cord plugged into an exterior house outlet. I'll make the assumption the generator can handle but would prefer to run off the electricity from the house when here.
Do I need to install a new breaker at home that has the capacity to power the coach including the A/C units on a 39' coach?
2008 Itasca Meridian 39z
31 REPLIES 31
time2roll
wa8yxm wrote:
Time Roll did you read the face of that outlet you posted
30 amps 125 Volts.
As I said up thread. Many electricians do not read.
Yes of course. Both NEMA 5-30 and 30-TT read the same.
The issue is the 30-TT looks very similar to 10-30 and in it goes at 240 volts.
Electrician knows 5 series is 120v. I think it should have been named 5-30-TT
w4phj
Advise your electrician you simply want a standard 50A range outlet installed. Suggest that you request he install the ground at the top of the outlet so your RV power cord hangs freely. I used 6 ga wire for a run of about 15 feet.
2021 Winnebago View 24J
2021 Ram pick up
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
wa8yxm
30 amps 125 Volts.
C20
Dennis,
Spot on. In my 34 year career as a firefighter I ran two house fires with RV's plugged into undersized wiring. Burnt up the RV and the house in both cases
2017 Newmar Essex
97 Jeep Wrangler
16 HD CVO Street glide
2015 Challenger Hellcat
2021 Hellcat Durango
2020 ram 2500 Cummins
tragusa3
I thought I was getting by with my 20amp garage plug running one A/C. However, with the recent installation of an EMS, it is shutting me down due to low voltage that I wasn't aware of. So, be careful, just because its running doesn't mean it isn't harmful. Fingers crossed I didn't do significant damage.
New to us 2011 Tiffin Allegro Open Road 34TGA
Join us on the road at Rolling Ragu on YouTube!
time2roll
CA Traveler wrote:
It's unfortunate IMHO that a unique 120V 30A RV plug that is almost identical to the common 3 wire 240V dryer plug was used for RVs.
NEMA resisted recognizing the 30-TT for a long time and I assume partially for this reason of similarity. Besides NEMA already had a 5-30 connector that is not confusing.
Trouble is the 30-TT is so widely used for a loooong time.
PNW_Steve
Timothy2001 wrote:
Executive wrote:
Whoa Kimo Sabbe! It's a bit more complicated than simply replacing a breaker and receptacle. That is unless your home fire insurance is paid in full, you no longer like your house, and the insurance company won't find you at fault for frying all the wiring inside your box. Generally, 20amp service, (Tee shaped receptacle) uses 12 ga wire, 15amp service (Double I shaped receptacle) uses 14 ga wire. 50amp service uses a minimum of 10ga wire, depending on the length of the run. Simply changing out the breaker and receptacle will allow you to power up you A/C units for a bit as your breaker will not trip. However, your house wiring will then become a substitute for your breaker. Once the wiring gets too hot, it will melt and burn through if you're lucky. If you're not so lucky, it'll simply start a fire and burn your house down. Hire a licensed electrician....Dennis
LOVE THIS! I learned a long time ago what I am capable of, what I am not capable of and what is just plain stupid to attempt and this falls under the later.
Anyone who was in the Navy remembers, "The Deadly Shipmate" and I prefer not to mess with electricity at sea or on land unless it's a simple light switch or house outlet.
Smart man!
Know what you know and know your limits. Someday I'll learn to do that..
Also, be cautious when it comes to taking electrical advice from an Internet forum.... I'm except Mike Holt's 🙂
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
mtofell1
Timothy2001 wrote:
mtofell1 wrote:
Getting a full electrical service at home is a really nice thing to do/have done. I love being able to use my RV to the fullest even in the driveway (hell, even the "doghouse" isn't so bad when DW sends me there :))
Next step is to be able to dump tanks at home. This was a real game changer for me. No more waiting in line heading out of the campground on Sunday. No more making the kids "hold it" until we get home.
So is this a 'hostile integration' into the plumbing that goes out to the street assuming city sewage and not septic?
Very appealing to me too.
Yep! That's it 🙂
Most municipalities frown/forbid this but it really has nothing to do with anything functional. It's just that they want to be sure you are paying them for the water you are dumping. Of course, they have no problem charging us to dispose of water we empty onto our lawns and plants all summer.... or, put into our RVs before leaving home and dump at the campground.
Anyway, gravity feed to a 3"+ cleanout is great but if you don't have that, a macerator and garden hose is amazing. Going to this setup is one of the best things I've ever done with respect to RVing.... no more "stinky slinky". Most times when I'm out I just attach the hose (without the macerator) to deal with gray water. I deal with the black once at home on my own time.
CA_Traveler
dalenoel wrote:
wa8yxm wrote:
Final note.. I know the TT-30 (30 amp) Outlet looks a lot like a 240 volt Big, Black, Large blades. MANY Electricians hired to install one will think that too.
And blow all your electronics
It is 120 volt. Says so right on the outlet.
Had a friend just get this done by a licensed electrician and is now having the RV, brand new, fixed since it was 240V and not 120V. Question the electrician as to what he is installling and then double check with your own VOM.
X2
2014 Grand Cherokee Overland
Bob
PNW_Steve
BB_TX wrote:
I can run one 15k A/C on a 20 amp outlet as long as I run nothing else. But I would not do it on a long extension cord. On 30 amp you can easily run a 15k A/C plus a few other lower current things. On 50 amp you can run all you want.
Make sure whoever installs the new outlet understand how it should be done.
http://www.myrv.us/electric/
My experience as well. A 20amp circuit and either no extension cord or a relatively short HEAVY extension cord. I have a 50' 10gauge extension that I have used with good success.
I did find that at times I wanted to run both a/c's and the refrigerator on electric while preparing for trips or working on projects so I finally installed a 50amp circuit.
Good point about making sure that the electrician understand that this is for an RV as there are different styles of 50 amp recepticles. I have gone out and replace a few of them...
dalenoel
03 Monaco Neptune 36PBD DP - 18 Focus Toad
Wife, myself, and Oreo the Malshi
wa8yxm
Ok the rules per Reddy Kilowatt
On a standard 15 amp house circuit you MAY be able to run ONE A/C. but nothing else.. on a 20 The A/C and converter if batteries are not hungry but again not much.
Keep the non-50 amp cords SHORT (Like one or two dogbones short)
on 30 amps one A/C and most other stuff but be careful A/C Water heater And microwave all at once and CLICK darkness ensues (Breaker trips)
My recommendation is have an electrician install a Dedicated 50 amp RV feed.
All the RV can eat...electrically
twodownzero
My ac runs fine on a 15 amp circuit as long as I use a good extension cord. Obviously I don't go trying to run the microwave and AC at the same time.
dodge_guy
I have a 30A outlet on the front of my house when I had the TT. Never had an issue running the single AC. Now with the RV I have 2 AC’s I just make sure I only run one which is all I’ll ever need to run at home. I don’t have a residential fridge so that is t an issue. So far I don’t have a need for a 50A service. Maybe someday but not now!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
