Jerry_Amerson's avatar
Apr 19, 2017
91 E-350 28' Fleetwood Floating/Hard to handle
I've had the Motor Home for 2 yrs and it has had a new gear box installed, assist rear leaf spring added, Safe-T-Plus steering shock installed, and I still am having problems with it floating on the open road. It has Kingpin suspension in the front which I understand can be shimmed or I've heard of a replacement that will allow easy caster/camber adjustments. Can anyone tell me what the best caster/camber degree is to keep it on the road and yet not wear out tires to quickly, and also if there is a mod that can be added.
Thanks,
Jerry
