Kenmartin1's avatar
Kenmartin1
96 thor motorhome slideout rubbing floor
I have a 96 thor motorhome, and one slideout is rubbing the floor. Is there an adjustment on these? Does it run on a track or just roll on the floor? It's a hwh hydraulic system. Thanks, Ken
  • Mine was doing that and after looking at the outside, there is an adjustment screw outside underneath. Loosen the bolts and turn it 1/4 turn, then retighten. See if its better or if it needs more. I marked everything so I could put it back if it didn't work. Mine quit rubbing though.
  • if its a level out room, the slide does ride on the floor. theres no fix. there is a nylon glide piece that is supposed to lessen the marks. just the way its designed.
