Chum lee wrote:
We're not talking about a Ford F150 with an small displacement Eco boost engine here. My take to the OP was to consider using a 2.7 liter boxer type engine in a much larger, heavier vehicle like a Ford E/F 450/53/550 hauling a Class A/C motor home at or close to maximum gross weight. An F150 is a half ton light duty pickup truck. Not the same thing at all. My compliments to Ford on getting a small displacement engine to work in the F150. I'm not holding my breath waiting to see when the engineers at Ford are going to drop one (eco boost) into a much heavier duty platform. That's a project for RCG's (recent college graduates) with stars in their eyes and no engineering experience.
Chum lee
The point is that manufacturers are willing to take risks if there are advantages. The eco-boost provides far less advantage than the OP is suggesting for this engine but Ford took that risk. They spend a lot of money and a lot of staff time on it.
If the OP's comments are correct, this engine would blow the ecoboost away in terms of both power and fuel efficency and be the logical replacement for everything from the compact pickups thru the 550 range (might have to be derated in the smaller trucks to keep it from being overpowered). That only strengthens the argument that it would allow the manufacturer who develops it to dominate the light to medium duty truck markets for years. Assuming they could make slightly larger version, they could take over the heavy duty truck market as well and a smaller version could take over the passenger car market.
The issue is not manufacturer's being scared of developing new technology. The issue is this is a pipe dream.
PS: My understanding is you won't see the ecoboost 3.5 in 3/4 ton or larger trucks. The issue is most 1/2 ton trucks spend 95% of their miles running around empty, so other than a few seconds here and there of hard acceleration, most of the time, it functions as a naturally aspirated engine and a V6 is plenty for that. When you do tow, the MPG goes down hard but as long as it's a small percentage of the miles, most are happy with the compromise and it doesn't affect longevity much.
In larger trucks with regular heavy loads and towing, the truck will be running boost a large percentage of the time. High boost comes with high fuel consumption, negating the MPG benefits and also high wear, so longevity becomes a problem.
I have heard rumblings about a V8 ecoboost that might work but not sure if that's reality or wishful thinking.
