Need some help finding a replacement fan motor for an older a/c/unit it's a colemen model # 6759A717 the motor part # 6757-311 I have called several places around my location here in AZ. With no luck ...
Some "Multi-Meters" (Digital Volt-Ohm Meters or DVOM) will test capacitors, and some of those aren't all that expensive. If you have power to the motor, and you could spin the motor over and see it carry on for awhile, I'm thinking capacitor. You don't need a "Coleman" capacitor, only one that has the same capacitance and voltage specs s the one in your A/C. Can you find an appliance parts store? My guess is the cap would cost $10 or so.
