May-16-2016 05:17 PM
May-11-2017 03:39 PM
LongWeekends wrote:
I have a couple of questions...what is the easiest way to determine which of the pigtails are for which unit? Is it just trial and error?
May-18-2016 06:05 AM
May-18-2016 04:53 AM
LongWeekends wrote:
A quick update. Thanks for your help! I unplugged each black and gray wire at the front AC unit and cleaned the connectors on all sides. The AC has been cycling off and on perfectly all day since then. I'm not going to jinx myself and say it is fixed but it is working properly for now.
Thanks for the help. I would have never gone down that path and figured it out!
May-17-2016 08:29 PM
May-17-2016 11:47 AM
dougrainer wrote:
Trial and error on which phone cable is which. easy to do tho. unplug one--if the wall tstat goes dead that is the tstat wire. if not thast wire feeds the middle ac. Now, that plug is the remote sensor plug which you do NOT use. Your wall tstat is the temp sensor for that AC. The Middle and Rear units will have that wire connected to a wall temp sensor. What you have exposed, is exactly where the corrosion usually is. Odds are you have a defective cable cut or shorted. The BLACK phone cables connect to the Circuit board, the gray phone cables go to the Tstat or the middle AC. Doug
May-17-2016 11:43 AM
Where do you typically find the corrosion? On the grey wire connector? Black? Both?
Dare I ask if it IS a bad cable, can I simply tie a new one to the old and pull it through or is it part of a big harness?
Finally, any idea what the unused plug that is hanging down is for?
May-17-2016 11:12 AM
May-16-2016 08:14 PM
dougrainer wrote:
Your Tstat should be controlled by the front AC control board. There are 2 power 12 volt wires to that control board. Make sure you have 12 volts positive and negative on the RED and BLACK wire feeding the front control board. This power wire set controls ALL functions of all 3 control boards. The 2nd AC control board is connected to the front and the 3rd control board to the Middle(2nd) by a phone type communication cable. So, your problem is either the Front AC control board or the telephone type communication cable between the Wall Tstat and the front Control board. It is extremely rare for the control board to be at fault on these type problems. At the front AC, you have a harness that has 2 phone type connections on 2 pigtails. Those pigtails are black. The wires running to the middle AC and the wall tstat will either be white or gray. Check the connections on the phone type modular plugs, disconnect them and look for corrosion. Your year and brand should have lo profile Penguin models. These are susceptible to excess humidity where these wires are and cause corrosion. The fix if you find rust/corrosion on the modular plugs is to cut the modular plugs OFF and install new modular plugs. If there is NO corrosion then the problem will be a defective phone type cable from any off the AC units and the wall Tstat. ONE shorted cable in any of these cables can cause a problem. The usual test is to take the wall tstat up to the front AC Modular cable connections and plug it directly into the front AC board with the Middle supply cable disconnected at the front AC and see if the front functions. If it does, you then leave the 2nd cable disconnected and reconnect the wall cable at the front board and reconnect the tstat at the wall and see if it still functions correctly. If it DOES your problem is isolated to the 2 rear AC unit control cables. If it does NOT, then your problem is between the front AC and the wall tstat on that cable. Doug
May-16-2016 07:18 PM
May-16-2016 07:07 PM
May-16-2016 06:35 PM
May-16-2016 05:41 PM
