psalm10720's avatar
psalm10720
Adding An Outside TV Hookup To A Brave
I have a 1993 Brave (27RC)and so far I cannot find an outside TV Hookup other than the outside stereo panel which does not have a pass-through door to allow a cable hook-up with the door closed. Has anyone ever added one and how did they go about it?
  • I have a 92 Brave and my coax cable has long rusted away. I'm not sure how moisture got inside, but the center solid core is gone. I'm sure yours is the same way.
    If you can find a good connection inside, I would just tap into it with a splitter and run the cable out the window. You could easily run it under the bench seat and install a hook-up next to your radio. It would be pretty simple to do and it would be a permanent solution.
    Tom
  • Winnebago's Owners Manual for your Brave states there is a TV hookup with the outside entertainment center. Page 65, Section 8-9.
    CLICKY
  • RoyB's avatar
    RoyB
    What I do is bring along a TV SPLITTER with a short male to male RG cable to hook up to the campground pedestal and then hookup my trailer the normal way to one port and then add a 25-foot RG cable to the other port and throw that under the RV so I can use it under the awning when we want to sit outside and watch TV sitting on an outside table next to the RV.
    Photo from google search
    Works for us.
    Roy Ken
  • Have you checked the top of all the compartments very close to the door frame?
