โJul-19-2017 04:27 PM
โJul-20-2017 05:30 PM
brianokeefe wrote:My 6V batteries are sealed AGMs, purchased from Sam's Club. I selected them because of the difficulty in monitoring fluid levels for my particular situation. My battery compartment originally had a slide-out tray for the lower profile 12Vs. I needed more height for 6Vs so the slide-out tray had to be replaced with a steel plate to gain enough height to get them to fit.
After the advice here and checking with battery stores it's obvious that any 12V set up would be no improvement and probably worse. I will explore the 6V solution and using sealed batteries can have one in the coach. I just need to find a good supplier as they are not available here in my town. My current coach battery is a 10" depth so that's the max I can go.
โJul-20-2017 04:18 PM
โJul-20-2017 10:59 AM
LOG wrote:
What would be a solution on my coach? I have three 12 volt batteries in parallel. Two 6 volt batteries would be less amp hours than the three 12 volt batteries. And, there is not enough room in the battery compartment for four 6 volt batteries.
โJul-20-2017 09:56 AM
โJul-20-2017 09:40 AM
brianokeefe wrote:Two 12V batteries in parallel, each in a differnet compartment with a gap between them is a very bad scenario. Two 12V batteries must be butted against each other with minimal length cabling between them. Even then it's not ideal as previously explained. You will do so much better separating two 6V batteries hooked up in series.
I can try and find 6V batteries of the size that will fit in my limited compartment space. It just fits the current 12V deep cycle one. I could get 2 larger (dimension) in which one fits into the battery compartment and one I could put in the closet and connect them in parallel. If I did that by connecting both to the inverter, thus they'd only charge or do nothing than run the 12V coach system, if the inverter isn't on. Is that a solution? Sort of loath to replace the inverter because 1) it was expensive and 2) it will run a toaster, coffee maker and even a toaster oven.
โJul-20-2017 09:35 AM
โJul-20-2017 08:53 AM
โJul-20-2017 07:30 AM
โJul-20-2017 07:24 AM
โJul-20-2017 07:11 AM
โJul-20-2017 06:48 AM
garyemunson wrote:Ah yes!
Adding to Ron's informative post, even when the charger is off, the mischief continues. The stronger battery will attempt to charge the weaker one until it is dragged down to the weaker one's level.The extra discharging cycles will quickly degrade the good battery to equal the older one.
โJul-20-2017 06:21 AM
โJul-20-2017 05:43 AM
โJul-19-2017 09:57 PM
