rgnprof
Apr 21, 2017Explorer
Advice - Roofing options
Haven't been on for a while, but spring is here...I have an older Class C - 29 ft. '93 Ford E350 - pretty good shape but I have to do something with the roof. I have to replace the shower skylight - cracks in the corners and I have some leaks in the roof, primarily where the EPDM wraps over the top along the edges and is then secured to the side of the RV. These problems are much worse in the rear of the coach...
I have patched along the sides numerous times and places with 4" Eternabond tape - generally with good success. But, I feel like I need to "fix it better"...
So, I'm considering 3 options - 1) coat the roof with one of those rubberized paints, probably just rolling it on over the Eternabond, 2) replacing all of the EPDM rubber, and 3) replaced the EPDM rubber from the shower skylight back to the rear of the coach only - about 12 ft. of the roof. I know the 3rd option may not make sense, but it would take care of almost all of my problem - PLUS it would be a whole lot easier. I know it adds another seam, but I don't have to fool with the AC or most of the top vents if I go this route and I could easily get it done in a day or two...I think!
What do you guys think? Is option 3 particularly short-sighted? Any other options I'm missing? We would like to keep this coach for another 3-5 years, but it is over 20 years old...
Thanks for any advice!
Ryan
Ryan
