Just s thought.
https://www.weigh-safe.com/An adjustable receiver head will level an empty car hauler.
Use a tongue weight scale while loading it.
‘Knowing the hitch weight’, which will change if you haul various cars or add and subtract weight in the rear of the tv.
Not that its a bad idea but you might not need the WD hitch. Adjusting the load front to rear on the car hauler will alter the needed tongue weight to the 10-15% mark. This can be done easier on a car hauler opposed to a travel trailer that you as well as myself are accustomed to.
This might be easier if you haul the same stuff all the time using the same hauler trailer .
