ugh wrote:
Wijames wrote:
Fishinghat wrote:
No, I don't know of any A/C that turns the fan off.
When your A/C is running, the compressor causes the coils to get cold on one side, possibly causing a build up of frost, and heat on the other side. The fan not only circulates the air but defrosts the cold coils and cools the hot side. The fan needs to run all the time to avoid problems.
You could try turning the fan speed down, but keep in mind that you may then have problems with the coils freezing up, especially in humid weather.
Do the fans on ducted air conditioners run all the time as well? I thought they shut off like a home unit. Also, can standard non-ducted air conditioners be set up to run off of a wall thermostat?
The fan stays on even for the units that are ducted. It does not function like home.
Actually the ducted A/C fans have auto setting on thermostat then they turn off when temp set point is reached just like home
Non ducted..no wall t-stat fans run until turned off
