โFeb-16-2016 06:06 AM
โFeb-18-2016 09:40 AM
โFeb-18-2016 08:12 AM
moisheh wrote:
You should check the unit as some Monacos of that era had both hydraulic and air leveling. Mr. Mark has the best system. His Liberty comes with a butler that does all the work!
Moisheh
โFeb-18-2016 08:01 AM
deandec wrote:LongWeekends wrote:deandec wrote:
We level our rig, then turn off the engine and dump the air. It usually dumps to a level attitude and can be adjusted manually from there. Yes the step is closer to the ground.
No. YES The Monaco came with hydraulic leveling jacks or the "upgraded" air leveling system. This has the air system, no jacks. Much to my surprise, once level it is rock solid!
My rig has no jacks. Why did you imply it does?
โFeb-18-2016 07:48 AM
โFeb-17-2016 04:39 PM
โFeb-17-2016 02:46 PM
โFeb-17-2016 10:53 AM
Kayteg1 wrote:
I did not like air leveling as even 15 tons coach will move with 100lb person walking around.
And if at any doubt - read the manual.
Too many variations in design to apply procedure from one system to another.
I remember practical advise for tilting jacks to move them to vertical position before dumping the air.
When you set the coach too low before tilting jack, they can hit the ground at angle with bad consequences.
Always check the jacks around before lifting.
โFeb-17-2016 10:23 AM
Bikeboy57 wrote:
Just to add to what Dennis explained very well.
The first step the HWH does in leveling is to release air to achieve level.
If, and only if, the HWH brain cannot level the coach by exhausting air, then it will cause the aux compressor to come on and the brain will inflate air bags to raise a side or end of the coach.
Because the HWH brain exhausts air first, you will find on almost all cases that the step is as low to the ground as it can be for the site you are parked on. Much lower than a jack based system.
โFeb-17-2016 07:34 AM
โFeb-17-2016 07:07 AM
โFeb-17-2016 01:57 AM
โFeb-16-2016 09:20 PM
โFeb-16-2016 11:26 AM
โFeb-16-2016 09:02 AM
