- Executive45Explorer IIILook in your fuel fill compartment, driver's side, right above the propane tank...should be covered with a blue snap off cover.....Dennis
If it's not there, call Monaco with your coach number or last six digits of your VIN. They still have all the info on file for your coach.....D. - donsuefuggrweExplorerIt is there. You just haven't found it yet. They like to hide it. Mine is in the outside fuse compartment under the drivers seat. To get enough pressure to fill your tires you have to use the cruise control. With engine running in neutral turn cc on and tap the speed increase knob to increase engine rpm. You can get 120+ PSI doing this. Also there is enough room to put a 50 foot air hose in there. 2001 National Tradewinds
- DSDP_DonExplorerIf you look in your generator bay, just to the left of your generator you should already have a quick connect fitting. Its for airing up your coach when it's being towed.
Many say they can, but I never got enough air pressure out of that fitting/tanks to inflate a tire over 100 psi. I put a hanger on the frame that the generator door is attached to and hung a 50' air hose there. It was good for blowing off shoes, clothing and filling small tires and inflatable toys. - jtfconsExplorerAre you sure you don't already have same?
Check in front left hand basement area, or in front generator area for a quick connector.
About Motorhome Group
38,708 PostsLatest Activity: Mar 04, 2025
