Alison transmission computer
Tom_Barb
Most probable cause ?
no shift panel lights,
no start.
ACC side of the ignition works, all systems work.
IGN side of the ignition works normal.
Strat position goes dead when you try to start.
Thanks for the help.
9 REPLIES 9
ArchHoagland
Thanks for the update, glad to hear it's fixed and I'll bet you are too...
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
Tom_Barb
We have discovered the problem,, we changed the Transmission ECU,, it did not fix the problem,,changing the major Battery cable fixed it.
corrosion ate the end of the cable nearly off. it will show continuity, but when place a load the cable would fail.
gatorcq
A friend went through this. Bad ground on/near the TCM.
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
ArchHoagland
Any luck yet? Besides bad luck....
US Gear Brakes
kane8907
How much does it cost to change an pressure sensor in a repair shop?
**Link Removed**
donkeydew
it can be many things when my cat low fuel pressure sensor when out it went blank
mobile mechanic scanned the engine and replaced the sensor all was good the allison pad lit right back up. i had called coach net and the first thing they ask was if the pad was lit,when i said no the ask if i needed a tow or or mobile mech.
larry_cad
Shift panel lights went out on mine, lost power to the panel. Apparently broken wire. Shop installed a new wire. All good.
Today is my personal best for most consecutive days alive.
Our Travel Blog
Tom_Barb
Mel Stuplich wrote:
Tom/Barb
No 12V power to the Allison VIM ... (blown fuse?/ bad wire?)
VIM. = ?
all fuses have been checked
all relays have been checked
all system operating.
except the start position.
the starter/relay/ ignition switch/ have been changed.
nothing fixed it.
Mel_Stuplich
Tom/Barb
